450R suspension
Old Nov 22, 2004 | 12:52 AM
Rcpilot's Avatar
Default 450R suspension
Dose any one know how maney inchs of sag on the front and rear shocks on the 450R this think is ruff riding **** I road a Z400 all stock it road much smother than my 450R on MX track
Thanks Tim
Old Nov 22, 2004 | 01:14 AM
twentycharacters's Avatar
adjust your shocks and it will be very different. i like the front shocks on this bike. they are pretty sensitive and it may only take a half of turn or a turn for you to see a difference. i went 1.5 turns out on my front ones and 5 clicks in the back and it made a big difference for me.
i wil add that IMO the rear shock isnt as good as the fronts. the compression adj is ok but seems that the rebound is lacking and can get things too springy. stock, the valving just isnt right.
Old Nov 22, 2004 | 01:32 AM
INSeaRChOFDUNez's Avatar
ELKAs all around.. +2 long travel arms axle and youll be set.
Old Nov 22, 2004 | 02:27 AM
Rcpilot's Avatar
What about the pre load or the sag on the spring ?
Old Dec 2, 2004 | 10:41 AM
jeepnrocks's Avatar
alot of people take the preload out to lower th bike and get better handling. my shocks are getting sent to c&d racing monday for revalving. i'll have triple rate fronts and a dual rate rear.
i'll have pics posted soon( along with the jillion others i have)
Old Dec 4, 2004 | 02:48 AM
ryangibson's Avatar
You aren't kiddin! I mostly ride full soft on the front compression with wheel spacers, and I still get terrible arm pump. The problem with this setup is that while it's still too stiff for riding in rough conditions, it's too soft for jumping...so I ride trails full soft until I get to the jumps, then I crank up the compression...SUCKS!
How much it would cost me to upgrade to double or tripple rate springs and get the shock revalved? I really don't want to spend a bunch of money on NEW shocks if I can just get away with upgrading the ones I've got for cheap.
Old Dec 4, 2004 | 03:29 AM
CroBiker's Avatar
works sells a triple rate spring upgrade for the fronts. i think it costs around $300. i got a set of works triple rates with remote rezzies for about $500, the catch is that i don't have ne adjustability. if i were you i'd go with the spring upgrade kit, and a re-valve.
Old Dec 4, 2004 | 03:33 AM
ryangibson's Avatar
What type of riding do you do, and did the new shocks make a significant difference?
Old Dec 4, 2004 | 10:16 PM
CroBiker's Avatar
i mostly ride dunes, with lots of big jumps and flat landings, so that's what i had the shocks set up for. they are night and day. for the first month or so i couldn't get over the difference they made. now i want to start desert racing so i'm goin to have the shocks re-built for that. i reccomend getting them rebuilt for trail riding, then they'll work good in the dunes, and everywhere else. with them set up for dunes they don't work so great on the trail, lots of feedback thru the bars.
Robinhood
Dec 26, 2015 10:28 AM
Asaran
Oct 8, 2015 11:14 AM
bigred20653
Sep 19, 2015 02:11 PM
chewy78
Sep 8, 2015 10:37 AM
Aug 5, 2015 02:10 AM
