Problems w/ Rancher AT's???
Old May 24, 2005 | 12:14 PM
  #31
cayer's Avatar
Default Problems w/ Rancher AT's???
Honda sent me a recall for this problem, it seems there is a programing error in the ECM that will cause this. The way they describe the problem is if you drop your speed to less than 8km/hr and speeding up again without coming to a complete stop, the machine will be left in a higher gear . It will eventually damage the clutch if the ECM is not replaced, so replacing the ECM is the only fix for this problem.
Old May 24, 2005 | 03:50 PM
  #32
charlieborg's Avatar
Update on the 04 Honda Rancher. I took it to the dealership, they replaced the ECM. took it home..still the same thing? So took it back, now they are replacing the clutches. I hope they got it this time! Any one live in Gainesville GA?
Old May 24, 2005 | 05:08 PM
  #33
yoda's Avatar
I think it will fix it. I had my ECM changed a while back and it ran really good for a while. I noticed it was ******* a little lately and I took it back in to be looked at and he said the clutch was shot. The mechanic said the clutch must have been close to being wore down when he changed the ECM before. He said the new ECM must have finished the clutch off. I am waiting to get mine back within the next few days. I am pretty anxious for it. It was a blast when I first had the ECM changed
Old May 24, 2005 | 05:22 PM
  #34
reliv007's Avatar
I live in cumming georgia its near gainsville or the "G" spot!!
Old May 24, 2005 | 05:26 PM
  #35
When they replaced your clutches, did they charge you for it? Or was it part of the recall on the ECM?
Old May 24, 2005 | 05:34 PM
  #36
yoda's Avatar
From my understanding it is under warranty, the original that is. Because they know it is a problem they should fix it.
I bought the extended warranty so I should be covered either way.
Old Jun 1, 2005 | 02:42 PM
  #37
12pointbuck's Avatar
The only problem I had with mine was a torn lower cv boot. The reason I bring this up is that the brush covers for the AT exposes A LOT of the boot when making hard right/left turns. I compared the exposure to my old 2003 rancher and it had much more coverage. This is a small thing but it had been broken for about a month so I ruined the bearing. Luckily, honda warranteed it.
Old Jun 22, 2005 | 01:57 PM
  #38
Ytown's Avatar
Originally posted by: charlieborg
Ok, seems like there are alot of Rancher owners here. I got a question on mine.(Ranches 400 at 4x4) I just traded for it a wekk ago. It starts out ok in auto from a dead start and shifts fine. But when i slow down , near 5 mph or so, and try to speed up, it just seems like it is slipping. But if you let it almost come to a stop, you can hear it go into first, then it is ok and goes fine. Is it normal for it to act this way? It's like it does not want to downshift to first at this speed. I can give it gas, but it just does not want to get going. it has about 1200 miles on it, and it's a 2004.
Mine does that every once in awhile, but only when cold. (Just started)
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
hondarider1234
Jul 21, 2015 11:53 PM
Scottma518
Jul 16, 2015 09:19 PM
RedRancher
Jul 10, 2015 06:36 PM
Scottma518
Jul 10, 2015 12:42 AM
