How do you get a 450R to start in the winter?
Old Dec 23, 2004 | 10:05 PM
ddininger's Avatar
Default How do you get a 450R to start in the winter?
I was wondering if onyone had found a good way to get a Honda 450R to start in the winter without it being in a heated garage. I have a completely stock 2004 450R with about 15 hours on it and it will not start if the temperature is below 40 degrees. I have starting fluid but was told it would possibly damage the engine. Any suggestions?
Old Dec 23, 2004 | 10:50 PM
86LT250RFatty's Avatar
Starting fluid can damage the piston... are you sure you put the choke on and your hot-start isnt on?
Old Dec 23, 2004 | 11:11 PM
deanz400's Avatar
thats y honda's last so long .. just joking haha
Old Dec 23, 2004 | 11:25 PM
LMFAO
Old Dec 24, 2004 | 12:11 AM
Redrizza's Avatar
I've owned honda's for years, and first thing you do if it's 20 deg. or lower is get on and rock bike back and forth, just a little, not violently or anything, for 10 seconds. This separates the air bubbles out of the fuel in the bowl so that the carb can pickup fuel better. With the choke on, it should just start. If it isn't than you need to increase your pilot jet size accordingly. I'd suggest 1 size at a time.
Old Dec 24, 2004 | 12:17 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
no help here,,,,sorry
one thing is for sure,,,,,the honda boys will have a ripped kickin leg come springtime[img]i/expressions/face-icon-small-tongue.gif[/img]
Old Dec 24, 2004 | 12:41 AM
hondabuster's Avatar
Now that the cold temps are here, the mixture is too lean at idle. A bigger pilot jet, or 1/2 turn more rich on the mixture screw should do it.
I wouldnt use starting fuild on a new motor, either.
If it just wont kick start and you want to go riding, have someone hook up a tow strap and pull start it.
Old Dec 24, 2004 | 05:57 PM
RoughRider01's Avatar
Before you kick it, pump the throttle one or two times, put the choke on, then kick it. Do not touch the throttle at all while kicking, a few stabs at the throttle before you kick it will help alot.
Old Dec 24, 2004 | 06:28 PM
Go put your battery on a tender and be quiet! lol [img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 24, 2004 | 08:26 PM
Bing's Avatar
Super Quad Patrol
just fired her today!!!
one touch,,,,,,,,,,braaappp!!!
