Ruby winch mount?
Old Sep 14, 2000 | 11:05 AM
chilldaddy's Avatar
You might be able to find some other place. Its pretty big, I know it will not fit under the seat.
You still have room for the winch controller and straps etc. in the tool compartment.
Old Sep 15, 2000 | 05:40 PM
Rubeman's Avatar
The review I saw on the Warn winch setup said that they mounted the solenoid inside the airbox. Surely there is a better spot. How about the rest of you with winches? Where did all of you mount yours?
Old Sep 15, 2000 | 06:16 PM
TxDoc2's Avatar
Mine are in the rear storage box.
Old Sep 15, 2000 | 08:42 PM
TEXMud's Avatar
Can you still access the tools?
Old Sep 15, 2000 | 11:39 PM
  #15
TxDoc2's Avatar
I have both my solenoids in the box. I just slide the tool container in over them. The tools won't fit in their original orientation, but they fit in the box, still.
Old Sep 16, 2000 | 02:03 AM
  #16
Rubeman's Avatar
Is the winch mount from OS one solid piece. It looks like the winch is bolted to the plate, and the plate extends out through the small opening of the plastic nose piece for the fairlead to bolt on. Is that correct?
Old Sep 16, 2000 | 06:01 PM
  #17
TEXMud's Avatar
Thanks for the info. I will mount mine in there sometime soon.
Old Sep 16, 2000 | 10:03 PM
  #18
Rubeman's Avatar
atvgear.com sells the Outdoor South winch mount for $35.00...NO shipping.
Old Sep 18, 2000 | 09:40 AM
  #19
chilldaddy's Avatar
The winch mount is a 1 piece plate that the winch bolts on to.
Old Sep 20, 2000 | 11:05 AM
  #20
Rubeman's Avatar
Well, I just got my mount from OS. Geez! Haven't they heard of grinder to smooth out the edges? It looks like they cut it with a torch, and then painted it. Oh, it'll work. It's plenty heavy enough. I take it you have to drill your own holes for the fairlead. Is that what you guys had to do?
