400ex back firing and sputtering
Old Jan 3, 2005 | 03:21 PM
bullhoggrande's Avatar
Default 400ex back firing and sputtering
Guys,
Another stupid question. I fired my 400ex (it was actually warm enough) for the first time since like September. It sputttered at first, which is to be expected. I got it to idle a little bit and figured I would run it down the road to blow the 'funk' out. It kept backfiring for like the first minute or so then it quit and ran like a scalded dog. Does that mean that my timing is potentially off, or could it be a function of non-use or bad gas? Any help would be greatly appreciated.
Tom
Old Jan 3, 2005 | 03:25 PM
ellett611's Avatar
I would say your gas i bad from the back firing or sputtering, but that is my opinion. I'm not an expert.
Old Jan 3, 2005 | 03:49 PM
cals400ex's Avatar
if the gas is that old, it was bad. i would replace the gas.
Old Jan 3, 2005 | 04:09 PM
Thanks guys. That is what I thought. I didn't put any stabilizer in there. I will put some new hi-octane.
Old Jan 3, 2005 | 04:19 PM
hondabuster's Avatar
If you plan on letting it sit, for more than a few days, with out being started, you might want to get in the habit of leaving the float bowl dry, while it sits.
Either turn off the gas, while idleing, when youre done riding, and let it die ( itll take a minute or so). Or shut it off, turn off the gas, and drain the float bowl with the screw on the bottom of the float bowl.
This will keep the carb , and the jets clean. Its the constant evaporation, and refilling of the carb float bowl, which condenses, and thickens the deposits.
Add the stabil, or other stablizer, to new gas..it wont do a thing for gas which has already gone bad.
Sjrpp
Jun 2, 2019 07:25 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
yambam13
Jul 4, 2015 01:49 PM
