HMF Install time in Rancher?
Old Jan 14, 2005 | 03:28 AM
Jspoon's Avatar
Default HMF Install time in Rancher?
How much work is involved to install an HMF in an 05 Rancher?
Are these so loud they can be annoying or is the sound a nice smooth loud tone???
Inquirering minds want to know.
Old Jan 14, 2005 | 09:44 PM
poopy's Avatar
my buddy has one on his z400 and we installed it in no time. but then you have to jet it properly. they are loud but they are not annoying loud its a nice sound.
Old Jan 15, 2005 | 02:19 AM
Jspoon's Avatar
Living in CO I ride at about 7-11000 ft, my jets are stock which tend to run rich, I have a k&n filter and opened up the airbox which helps, do you think if I do the hmf I would not have to re-jet as the pipe would equal out the mixture? At sea level how many jet sizes did you go up? Also is a Z400 a 2 stroke?
thanks
Old Jan 15, 2005 | 12:24 PM
TRIPLELSTROKER's Avatar
EASIEST upgrage you will ever do is the pipe..only takes a few minutes. Takes a little longer to rejet the carb and replace the needle.. The whole job shouldnt take you over an hour and half tops. I have installed one on my Foreman and installed one for a friend on his racher a couple of weeks ago. According to the paper work with the jet kit and our elevation, the Rancher's main jet size was increased two sizes..The Foreman on the other hand, said to lower the main jet size one size for our elevation. It makes a big difference on the Foreman, especially if you run it without the silencer insert, but on the Rancher 4x4, it will pull the front wheels when he hits second gear now. The rancher runs without the silencer and doesnt sound too noisey at all, just a good deep tone similiar to racing go-karts. The Foreman is way too anoying of a noise with the silencer removed, so i modified it to get the best of both worlds.
Old Jan 15, 2005 | 03:43 PM
poopy's Avatar
yes you will still have to re jet to see the correct power gains from the pipe. im not sure about sea level jetting. no the z400 is a four stroke.
Scottma518
Jul 16, 2015 09:19 PM
RedRancher
Jul 10, 2015 06:36 PM
Scottma518
Jul 10, 2015 12:42 AM
Mphillips
Jul 2, 2015 07:20 PM
