250r frame
Old Feb 7, 2005 | 07:34 PM
NBake's Avatar
Default 250r frame
wheres the best place to buy a trx250r frame? id like to get the 1987-1989 year, but ill take the 86 year.
Old Feb 7, 2005 | 07:42 PM
HA2's Avatar
HA2
Default 250r frame
if you got the money LSR, Laeger or Arens Bros. [img]i/expressions/face-icon-small-happy.gif[/img]
Old Feb 7, 2005 | 09:34 PM
NBake's Avatar
Default 250r frame
aint got the money tho, im partin out my old atv and tryin to buy a frame so i can custom build my own 250r
Old Feb 7, 2005 | 11:20 PM
schonertkyle's Avatar
Default 250r frame
Ebay is prob. the only place. I'm preety sure a 400EX frame would work, their practically the same. Walsh racing and Houser make frames to. I think LRD does also. Whats your price range your willing to spend?
Old Feb 8, 2005 | 04:11 PM
NBake's Avatar
Default 250r frame
im trying to find somethin under $1000, im expectin to get around 400 for parting out an old atv and then w/e i need to buy a frame. schonertkyle u said about a 400ex, have u seen them used before or know they will def. work?
Old Feb 8, 2005 | 07:52 PM
pendejo's Avatar
Default 250r frame
If you're building a "one off" quad, and not going with an aftermarket frame, I would look more into a 400EX chassis. They are round tube instead of square, which is much stronger then square tubing like the R.
Old Feb 8, 2005 | 10:17 PM
NichelsonRacing87's Avatar
Default 250r frame
yeah i'm pretty sure a 400ex frame will work also, they are the same basic quads, except on is a 2 stroke and one a 4 stroke.....i'm not so sure about round tubing being stronger than square, but 400ex frames are pretty strong, and so are stock R frames.
Old Feb 8, 2005 | 10:30 PM
NBake's Avatar
Default 250r frame
what about puttin the radiator in? will i have to do alot of fab. to get it to fit?
Old Feb 9, 2005 | 01:29 AM
pendejo's Avatar
Default 250r frame
Well, let me reword that, because I don't know if round V.S. square tubing,which is stronger chassis wise. What I meant was that round tubing will not crack as easily as square tubing. Round tubing would more likely bend, whereas square tubing would crack, if that makes sense??
As for a radiator, you will obviously have to fab up some brackets, but the R and EX chassis are very similar so it should fit without having to cut any of the frame.
Old Feb 9, 2005 | 02:25 AM
HA2's Avatar
HA2
Default 250r frame
agreed.
EIF
Apr 20, 2017 07:15 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
