Extra Fuel
Old Sep 19, 2000 | 08:00 AM
Code54's Avatar
How is everyone out there carrying extra fuel for their ATV. I was thinking of buying a fuel pak (a red plastic thing that mounts on the front rack, only 2 or so inchs high, think it is 3 gallons or so). Or the other idea was buy a small boat gas tank and mount it (small and mostly flat) and maybe run a second line to the carb so I wont have to remove it to use the fuel? Any ideas or thoughts? Thanks
Old Sep 19, 2000 | 11:35 AM
mntrailrider's Avatar
There is a comppany that makes a reserve tank that gets mounted on the back rack and has it's own fuel line and switch. Although I don't know the name.
Old Sep 19, 2000 | 03:01 PM
DrRod's Avatar
Greetings,
I've seen a rack that hangs over the back of the quad that holds a traditional 5-gallon jeep can. Check Northern, Cabelas, or some of the vendors on this site.
On the lighter side, you can put a 1-gallon plastic gas can (the squat/square design) in the rear storage compartment of the 450ES (maybe others too). Best to wrap it in a plastic bag to deter any leekage that might seep onto hot parts.
Old Sep 19, 2000 | 03:11 PM
trapperb1's Avatar
Check out IMS. They make fuel tanks. I don't know if they make one for your ride, but I have one. www.imsplastics.com
Maybe it'll help.
PrairieDog126
Sep 12, 2015 06:53 PM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
Rooky
Sep 9, 2015 03:16 AM
gogogo
3) General Discussions..
Sep 8, 2015 08:49 PM
Elkaholic
Sep 6, 2015 02:44 PM
