400ex noise and changing the oil
Old Apr 6, 2005 | 03:06 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default 400ex noise and changing the oil
I have found that Hondas and Suzukis are pretty clean from the factory, but still you want to be on the safe side. Yamahas are terrible. I don't think they flush them at all at the factory.
Old Apr 8, 2005 | 10:14 PM
Russo400's Avatar
about the cold start my quad dosent run eather right away so what i do is start it full choke and rev it for a bit then shut the choke off and still rev it for a bit then it should idle. Also when i ride a hear that noise to and what i think it is the chain roller because you hear it more when you go off jump and the swing arm is hanging but that just what i think it is
Old Apr 8, 2005 | 10:23 PM
powerslider's Avatar
You can easily cure the cold bloodedness by installing a larger pilot jet in the carb, they are very lean from the factory on the pilot. Stock size is 38, I switched to a 42 and problem is gone....
Old Apr 8, 2005 | 10:52 PM
Honda1478's Avatar
I think your right russo, thats when i hear it also, when im in the air.
Albertaboyy
Sep 9, 2015 09:51 AM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
Jason Campbell
Sep 7, 2015 02:25 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
Elkaholic
Sep 6, 2015 02:44 PM
