adjusting ign timing
Old Apr 10, 2005 | 01:19 PM
brianteel's Avatar
Default adjusting ign timing
is there a way to adjust the ign timing...not the valve adjustment.
what is the timing and how do you do it
Old Apr 10, 2005 | 02:09 PM
hondabuster's Avatar
To mechanicly advance the timing, its not really adjustable, in the sense, a car is. The flywheel key can be replaced with an advanced key, but then its fixed at that advanced rate, which isnt always desirable. It can make for higher operating temps, and hard starting.
Heres an article on how to do it.
advance key
Old Apr 10, 2005 | 03:51 PM
brianteel's Avatar
I am trying to figure out what is wrong with 400ex and by the sound of it it cant be the timing
Old Apr 10, 2005 | 07:33 PM
What are the symptoms? When does it do it? Cold but not hot? full throttle , or idle, or in between? Hard starting?
Old Apr 10, 2005 | 09:21 PM
brianteel's Avatar
http://forums.atvconnection.com/mess...TARTPAGE/1.cfm
that is my post with the problems...only when hot and all threw the throttle range
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
MNatv89
Jul 7, 2015 11:36 AM
Sjrpp
Jul 5, 2015 09:04 PM
