400ex pipes... HELP
Old Oct 2, 2000 | 09:59 PM
BLC's Avatar
BLC
i have a stock 400ex... i wanna know which is better... the WB eseries slip on or the WB eseries full system which includes the oversized headers... i hear from some that the header will make u loose power... i dont see how that makes sense... someone please help... and by that way... if there are any other pipes that compete with the WB eseries please let me know and tell which is better the slip on or full... thanx
Old Oct 2, 2000 | 10:23 PM
2k400ex's Avatar
i got the slip-on, with 12 discs, modified airbox, and jetting, its a nite and day difference.
ive read where the stock pipe is actually good, for the stock motor, if you plan on some motor mods down the road, proably the Pro Meg is best since you cant upgrade with the s-bend to pro meg.
400ex
14t sprocket, s-bend, renthal bars
Old Oct 2, 2000 | 10:32 PM
Santa's Avatar
Yoshimura Full Exhaust System!!!! Same power as WB and looks so much better!
Old Oct 2, 2000 | 10:37 PM
BLC's Avatar
BLC
hey santa how much did your system cost...
Old Oct 2, 2000 | 11:01 PM
Santa's Avatar
BLC,
I have the Pro System which full Titanium, I think it retails for $650. I paid $500 to a friend who works for the dealer.
It is the best looking system you have seen!!
Old Oct 2, 2000 | 11:07 PM
BLC's Avatar
BLC
hey santa i dont have 650 bucks to dish out but i do have enough for the standard yrd series.... besides the weight difference is there any difference in performance between the standard and pro race series???
Old Oct 3, 2000 | 12:11 AM
Santa's Avatar
BLC,
The only difference is weight. My friend has the standard full system and I cant tell a difference in the two quads.
The header pipe was much larger then the stock one.
Old Oct 3, 2000 | 12:48 AM
BUBBAG's Avatar
DMC DMC DMC! ! ! HOW MANY TIMES DO I HAVE TO SAY IT..IVE RIDDEN WITH JUST BOUT EVERY HI PERFORMANCE PIPE, THE DMC LOOKS, SOUNDS, AND PERFORMS BETTER THAN ALL OTHERS IVE RIDDEN, IT IS BOUT THE SAME AS THE DUNCAN, THE TOP OF THE LINE PRODUCTS IN QUADS, BUT IS MADE EVEN BETTER...DMC USES A SOLID MOUNTING BRACKET WHICH KICKS THE MUFFLER AWAY FROM THE CALIPER, SO IT WONT HIT AND BREAK OFF, THE DUNCAN IS STILL USING THE METAL STRAP, PUTTING IT RITE OVER THE CALIPER...IT IS CERTAIN TO HIT WHEN YOU BOTTOM OUT, AND BREAK
Old Oct 3, 2000 | 10:52 PM
bigboy400ex's Avatar
BLC YOU WILL HAVE TO DECIDE FOR YOURSELF ....I MYSELF WHO WORK FOR A DEALERSHIP BOUGHT A YOSHIMURA FULL SYSTEM ...$477.99 RETAIL..
LOOKS GOOD AND SOUNDS GOOD ...
Old Oct 4, 2000 | 02:59 AM
nigman's Avatar
Santa
Do you work at Conklin Cycle in Conklin NY by any chance?
