SOS! Checking OIL on a 300EX
Old Oct 3, 2000 | 09:50 AM
Madmike101's Avatar
Does the dipstick have to be screwed in or out to get the proper reading. I bought the quad used with no manual.
Old Oct 3, 2000 | 10:23 AM
cstark's Avatar
Take the measurement with the cap screwed all the way in.
After an oil and filter change. The machine should be filled with 1.6 quarts of fresh oil.
Old Oct 3, 2000 | 11:45 AM
hiofcer's Avatar
Sorry cstark, Not to undermine you But, According to the owners manual The dipstick should NOT be screwed in for an accurate reading.
Old Oct 3, 2000 | 11:56 AM
cstark's Avatar
I have the shop manual.
It says too screw it in all the way.
Engine oil:
After rebuild - 2.2 quarts
After filter change - 1.6 quarts
Oil change without filter change - 1.4 quarts
It is also a good idea too run the motor for a minute or 2 before checking the level.
No matter how you check it, it is pretty hard too screw up.....
Old Oct 3, 2000 | 11:57 AM
slim_101's Avatar
Holy Sh**
I never knew
Right from the 00 300ex owners manual page 96
1. Make sure the vehicle is on level ground.
2. Start the engine in a well-ventilated area and let it idle for a few minutes.
3. Stop the engine.
4. After a few minutes, remove the oil filler cap/dipstick from the right crankcase cover and wipe it clean.
5. Insert the dipstick without screwing it in, then remove the dipstick and check the oil level. The oil level should be between the upper level mark and the lower level mark on the dipstick.
6. If required, add the specified oil into the filler cap hole, up to the upper level mark on the dipstick. Do not overfill.
7. Reinstall the oil filler cap/dipstick
Old Oct 3, 2000 | 12:05 PM
cstark's Avatar
Take anything the Owner's Manual says with a grain of salt.
If I'm not mistaken, it says too always ride your new FourTrax on level ground.
I think the lawyers' write these things too be idiot proof. Just too cover thier butts.
Multiple steps too take a measurement would be complex, and confusing.
Screw it in, don't screw it in. Either way....If you are checking the oil, it is probaly time for a change anyway.
Old Oct 3, 2000 | 01:30 PM
Madmike101's Avatar
Thanks guys, I was having this debate with some of my fellow honda mates and I thought I would throw this question out there for some text book input.
Old Oct 3, 2000 | 01:51 PM
hiofcer's Avatar
Thanks... When all else fails, read the directions.
Old Oct 4, 2000 | 01:39 AM
puddding's Avatar
yup....don't screw it in
either way it won't cause serious harm......unless the bike is getting a real work out
either way it still sits in the normal operational range.....between both marks
wonder how many people actually don't know that.....my father parks his bikes on flat ground the night before and just unscrew the dipstick to check before next use......turns out its wrong.....and he always moans becasue the bike is always over filled......!
....ps you have to stand on your head to get it exactly right...lol
slowgsxr97
Mar 18, 2022 03:40 AM
COFatboy
May 2, 2020 12:06 AM
Asaran
Oct 8, 2015 11:14 AM
Blueholleroffroadpark
Where to Ride
Jul 30, 2015 05:39 PM
