pistons
Old May 11, 2005 | 03:47 PM
REDEX300x's Avatar
Default pistons
if i want to install Wiseco High Compresion Piston how much compresion should i get? i got stock engine only uni filter on it...(i got ex 300)
plus what it will give me [img]i/expressions/face-icon-small-smile.gif[/img] ? and what i need to add for it to work properly
thanks and sry for my ignorce
Old May 11, 2005 | 09:21 PM
Doctorturbo's Avatar
GOT BOOST!
Default pistons
The more compression you put to your engine the more power you will make. It's not linear though. In other words you will find a lot of power if you go from, lets say 8 to 1, to 11 to 1. You won't find as much if you went from 11 to 1, to 14 to 1 even though you went 3 points higher on both.
Nothing more than a piston to make it work. It would be better if you had other stuff like a cam and a pipe and match all of it, but it will work with just higher compression.
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
