450r rejet
Old May 13, 2005 | 12:39 AM
fred600rr's Avatar
Default 450r rejet
MY 450r is hard to start so i move the C clip down one so i move the needle up. It starts now on the second kick but bogs after half throdle i have a 180 main do i new to go up still I turn the full mixture srew out with the needle was on the 3Rd setting and it did nothing for starting The needle is on the 4th form top and 180 main (dyno jet kit) Any suggestion for what could help the bog after half throdle thanks
Old May 13, 2005 | 01:50 AM
TractorPacker's Avatar
Do you have a balloon?
Default 450r rejet
I think most guys are raising there needle to the top. I think I raised mine one???, but not sure. Its a pain to get to the needle but it seems like a good try.
Did you increase your pilot jet one size? If not do that first.
Old May 13, 2005 | 02:50 PM
450r969's Avatar
Default 450r rejet
call the dealer put all the settings back to stock and then go from there. it all depends what kind of mods you have and since oyu have the same thing as mine was if you have the lid on take it off thats a big issue when i got mine ported the first time and get a smaller needle i got mine from janssen racing and that should be good at up down one clip so try that.
Old May 13, 2005 | 08:51 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
Default 450r rejet
Fred,
I have almost the same mods but I have the stock muffler with the 2" end cap installed. I have a stage II Hotcam and modified airbox lid.
I went to a 180 main jet, a 40 pilot and raised the needle up all the way. I didn't have to change the fuel mixture scew and it runs great.
I'm know that a dyno jet 180 is different than a kehien 180, but I'm not sure how much.
Old May 15, 2005 | 10:46 PM
fred600rr's Avatar
Default 450r rejet
red400exrod
Do you mean you have a 50 pilot and are you using stock needle or dyno jet thanks
Old May 16, 2005 | 12:01 AM
Pirate Biker
Limping Rider!
Default 450r rejet
Sorry fred, I went to a 50 pilot (not 40) dropped the clip on the stock needle to the bottom, used a 180 kehien main and didn't change the air mixture screw.
Old May 16, 2005 | 09:02 PM
fred600rr's Avatar
Default 450r rejet
thanks
Asaran
Oct 8, 2015 11:14 AM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Aug 5, 2015 02:10 AM
cSchwartz
Jul 9, 2015 02:43 PM
