250x hard starting when warm
Old May 18, 2005 | 09:56 PM
lucky6man's Avatar
Default 250x hard starting when warm
just as the tittle states when its warmed up its vary hard to get started. but when its cold its alot esier to get going. what could cause this?
Old May 18, 2005 | 10:16 PM
87250xman's Avatar
I had that trouble with mine. It turn out to be the CDI. But it could also be the coil or plug.
Old May 19, 2005 | 07:37 PM
IATVHSSracer's Avatar
Mine also did that it was i thought it wasnt starting and i jsut wasnt kicking hard enough or it is your carb or filter mine had the stock filter in it when i got it and it was jsut and made it not start but i got a new one and she ran fine but try kicking it a little harder i race mine in the iowa atv harescramble series and it died on me and a guy that had wrecked cam over and asked me what happend and i said it wouldnt start he said he ahd one and he got on it and kicked it extremly hard and it fired right up so have your dad kick it or kick it as hard as you can and it should start thats ust my 2 sence broc bromley #128
Old May 19, 2005 | 07:55 PM
lucky6man's Avatar
well i dont thinking kicking it harder is the problem. im the hardest kicker around (im the only one who used to always be able to get it started) the frame sat out side during the winter (it started fine befor) when i was rebuilding the engine could that have messed up the cdi or coil(siting out side)? ill try a new plug if that dosnt help witch should i replace next?
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
chinkapin
Jul 14, 2016 06:58 AM
Jbird4681
Jun 9, 2015 01:59 AM
1000gade
May 27, 2015 12:37 PM
