250x questions
Old May 26, 2005 | 10:29 PM
lt230s4life's Avatar
Default 250x questions
ok i have a 92 honda 250x and i want to get a 400ex carb is that good. i want to get a whitebros pipe instead of the junky dg one/ also i want lots of bottom end sowould the best thing be a stroke kit(if they make one) also what else should i do to it cuz i want bottom end. thank for any answers
Old May 26, 2005 | 10:42 PM
TractorPacker's Avatar
Do you have a balloon?
Go to Powroll.com. They have a nice stroker kit that pushes the 250 to 313 I believe. If you want bottom end a stroker is the quickest way to do it, just not the cheapest.
As for the carb, the bigger the bore the more top-end power. I would think stay with the stock 32 mm carb.
Old May 26, 2005 | 10:48 PM
i looked its not for the 250x jus the 300ex
Old May 26, 2005 | 11:08 PM
300exStroked's Avatar
250's and 300's have many interchangable parts.. the only difference on the 250 stroker is that its a little bit longer for the kick starter.. i put a 250x stroker in my 300 .. but you can't go the other way with that
Old May 26, 2005 | 11:31 PM
yeah check again its for both
Old May 27, 2005 | 12:25 AM
1988fast250x's Avatar
hey dont go with the stroker kit its a waist of money + dont go with the white brothers pipe dont like them go with the yoshe or any of the FMF pipes. oh by the way trackor packor the stock carb is a 28mm I know b/c thats the one that came off of my 250x when it was stock!! if you want the bottom end without spending alot of money go one tooth down on the front sprocket.or spend about 2000 doing what i did and be beside the 400ex or dont its your choice. well i wouldn't get the stroker kit b/c it tears motors apart fast makes them not reliable also i think you half 2 run race gas not sure but if you do that can get alittle $$$$$.. so here is what iv done 2 mine oh also have you thought of lightening the bike like im doing right now like A-arms, axle, swing arm, shocks all of that stuff???
also you can get a tourqe cam that would help!!
1988 250x
80mm big bore kit
proformance cam
proformance valves
bigger valves
ported and polished
34mm mikuni flat slide
FMF mega max pipe
14 tooth front sprocket
uni air filter
DID O ring chain
VP race fuel
Lone star X33 axle +4
billet hubs
13:1 compression
race cut finders
holeshot tires
ac nerf bars
ac grab bar
fly handle bars
shock covers
no air box lid
pro kill switch
scott grips
lonestar axle carrier
new timing chain
new cam sprocket
new rear sprocket
painted the frame silver
Right beside the 400ex
Old May 27, 2005 | 06:16 PM
thanks man i guess i wont go wit the stroker kit but i will look at a that cam also one tooth down and other way i can get bottom-end not to worried about topend anymore
Old May 27, 2005 | 06:26 PM
also will an oil-cooler help any
Old May 27, 2005 | 06:29 PM
I have no idea but if you figure it out let me know also how 2 make it work i wouldn't think it would help just let the oil stay cooler thats all but let me know.
THANKS
Old May 27, 2005 | 06:30 PM
one more thing why do you wnt so much bottom end you better have a great grab bar [img]i/expressions/face-icon-small-smile.gif[/img]
