need more power honda rancher
Old Jun 17, 2005 | 10:49 PM
quicksilver's Avatar
Default need more power honda rancher
i think honda has a jet kit for high-altitude riding. It's designed if you ride above a certain level, you might want to find out what that is, and if you are above it, get that kit. it might help...
but the rancher isnt very powerful anyways. It's kinda a hog sometimes compared to the bigger 500 foreman, but it's ok for what i use mine for. You could try a different muffler and jet kit, etc., but you would have to go to a big bore kit and cam for a serious upgrade, and that would mean taking part of the engine apart. not to mention reliability problems down the road because of all the extra stress on the engine parts.
otherwise you could try to find a foreman 450
Old Jun 18, 2005 | 02:37 AM
RedGoblin's Avatar
Originally posted by: ixRAZORxi
thats a dum question.
If it's such a "dum" question, why can't you answer it? Shocks will not make you "faster" in a smooth run, only if you have to deal with whoops, jumps, very aggressive corners, etc.
Old Jun 18, 2005 | 09:39 AM
ixRAZORxi's Avatar
shocks make you faster. Thats the best upgrade you can get.
Old Jun 18, 2005 | 11:43 AM
CrazyJames's Avatar
Just out of curiosity. When was the last time you did a tune up and adjusted your vavles???? Also check you carb for restriction due to fuel gumming or dirt. Just some tips to ensure the bike is up to speed.
Old Jun 18, 2005 | 12:41 PM
  #15
iwantaTurbo's Avatar
thanks for the tips!!!! ill see what i can do.
Old Jun 18, 2005 | 04:33 PM
  #16
RedGoblin's Avatar
It very much depends on the kind of riding you are doing. In a drag race on pavement, engine and power modifications are the best upgrade you can get.
Old Jun 19, 2005 | 10:38 AM
  #17
ixRAZORxi's Avatar
why would you drag race a rancher on pavement?
Old Jun 20, 2005 | 05:56 PM
  #18
RedGoblin's Avatar
My point is, how are shocks the single greatest speed investment you can make to any quad?
Old Jun 20, 2005 | 10:04 PM
  #19
ixRAZORxi's Avatar
Make a new post and ask that question.
Old Jun 21, 2005 | 03:05 PM
  #20
pat89's Avatar
Without going into the motor, jetting is the best way to gain power. A muffler and K/N is not going to do much by themselves. Add a jet kit and it will wake the Rancher up. The best muffler for a Rancher is the HMF Utlity but it is a loud pipe. Have you done the throttle cable adjustment? It has way too much play in it from the factory. I would keep the K/N. It flows a little better than the Uni but you need to use an Outerwears pre-filter over top of it to keep dust out of your engine. If you ride in any mud and water, seriously consider either sealing your pull-start up with rtv silicone or investing in one of the block-off kits. I do not recommend big bore kits for the Rancher because they do not handle them well. The Rancher will never be a speed machine but the above mods do make them more agile.
