Timing chain keeps slippin please help.
Old Jun 20, 2005 | 04:52 PM
240YBlaster69's Avatar
Default Timing chain keeps slippin please help.
I just bought a new cam for my xr200, which is the same motor as the trx 200x and when i put it all back together, timed right. It ran like a champ forabout 2 hours. I shut it off to let it cool down and it fired really weak. i took it apart and saw that the cam skipped 4 teeth. when i looked at the tensioners and they show no strength on the timing chain. is there a way you can adjust em on this kind of bike. they said its a spring loaded tensioner. thanks
Old Jun 20, 2005 | 08:28 PM
yamahawarriormods's Avatar
are u sure the chain is not streched... i would not ride your bike untell u figure this out i wish i could help more
Old Jun 22, 2005 | 12:53 PM
ThrashAndCrash's Avatar
There is only a couple things that can go wrong.
1. The spring tensioner is week or sticking (some years are adjustable)
2. Cam chain is stretched (how old is your current one?)
3. Cam / crank gears are worn
4. or the cam chain guides are bad. (this is usually the weak spot)
What year is your XR? For $40 you can get a new cam chain and guides.
Hankey Pankey
26
Oct 18, 2020 03:50 PM
armpump450r
Technical and How-To Articles
Apr 1, 2017 06:11 AM
cornermike
May 27, 2015 10:04 PM
ragewraps
May 27, 2015 08:07 AM
Polarisman1123
May 25, 2015 10:03 PM
