HELP!! with my girls 400!
Old Jul 6, 2005 | 02:00 AM
coolintheice's Avatar
Default HELP!! with my girls 400!
She has a 2000 400 ex, it has a HMF slip-on, K&N filter, and a open airbox (no lid). It also, 70 degrees out and we are at sea level. At just off idle it burbles really bad and blows black smoke. Main jet is a 170, airscrew is at 3 turns out and the needle is at three notch up from the bottom. It runs really good threw the mid and top end. Any help would be great.
Old Jul 6, 2005 | 09:31 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Did it run good before, and this is something that just came up??? If so, sounds like something clogging a jet.
Or did you just put on the pipe, etc., and you don't yet have the jetting quite right???
Old Jul 7, 2005 | 12:27 AM
I just put the pipe on, and started to noticed the black smoke.
Old Jul 7, 2005 | 01:08 AM
Red Rider
So you attempted to rejet for the mods??? (I can't remember what the stock jetting is.) If not, you have been running lean, and your engine may be toast.
Old Jul 7, 2005 | 01:55 AM
MeYHymN's Avatar
Black smoke usually means rich. When you make a change to the intake/exhaust system you have to make changes to the carb. Changing the pipe allows more air which usually gives you a leaner mixture, but that sounds opposite of what your experiencing. This should explain everything you need.
Old Jul 7, 2005 | 02:28 AM
Killer site! thanks. Im thinking the quad is running fat and I need to adjust the air/fuel screw.
Old Jul 7, 2005 | 08:48 PM
snowbuster's Avatar
Well if you haven’t touched the jets I would. A screw isn’t going to do anything you need to rejet if you haven’t.
Old Jul 7, 2005 | 09:51 PM
allready rejetted it. going to try to reset the airscrew to 2 turns out.
MooseHenden
Family ATVing Photos
Oct 5, 2015 08:14 AM
Mikesohio
Jul 26, 2015 10:51 AM
kwackermann
Jun 24, 2015 10:18 AM
scramdaddy400
Mar 31, 2003 01:27 PM
