just installed new main jet---help
Old Jul 13, 2005 | 03:18 AM
wsy480's Avatar
Default just installed new main jet---help
started the bike up and it just runs like a raped ape with no throttle applied like i have throttle on what would be the prob?....is the norma do i just need to idle it back or something??help help help
Old Jul 13, 2005 | 09:10 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Is your slide stuck partly open?
Old Jul 13, 2005 | 12:12 PM
wsy480's Avatar
would that be the only reason?
Old Jul 13, 2005 | 12:39 PM
Opteron's Avatar
try moving the needle down
if your slide isnt stuck partly open, that is
Old Jul 13, 2005 | 12:40 PM
CamoKodiak450's Avatar
Has Been Around Here Quite Awhile!
It's your slide. I did the same thing. You've got it in 180 degrees backwards. I about craped my pants when I first started it up, I'm sure you did too![img]i/expressions/face-icon-small-happy.gif[/img]
Old Jul 13, 2005 | 12:56 PM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
Some have a notch for the throttle cable. If you don't get it in right, it'll stick open.
Old Jul 13, 2005 | 07:16 PM
tprender's Avatar
You could also have the cable pulled out of the housing. This pulls the slode all the way open . Check this before you take the carb apart. Try working the throtle and listen for the slide with the engine not running.
Old Jul 13, 2005 | 09:20 PM
wsy480's Avatar
thanks guys ill gave all that a try from the easiest to the hardest.....the forum rocks tons of help.....and yes i did crap my pants....one cause it was running like that and two cause i may have to take it off again[img]i/expressions/face-icon-small-sad.gif[/img]
Old Jul 13, 2005 | 10:45 PM
cals400ex's Avatar
see if you have any slack in the throttle lever..... if not, you could have possibly turned the cable some. you just need to loosen it up at the housing on the handlebars where the cable enters. if there is slack in the throttle lever, you will have to take it apart again i guess.
Old Jul 14, 2005 | 03:19 AM
wsy480's Avatar
found it guys it the last half of the throttle cable didnt seat into the grve got it together and it runs awesome now.......next.....im thought that the elctrode would have color all im getting is a blacker color around the rim not on the electrode...its clean as a whistle....this good or bad??
ReconBayou
Oct 31, 2022 05:37 PM
2many2ride
Sep 27, 2015 04:35 AM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
