what is so great about k
i dont really like them because they are wire filters and suck too much stuff through
The only way there will be problems with them is if you under oil them, over oil them or don't clean them like you should. The only thing they don't like is water. Being cotton, they don't like water.
If you think K&N is bad, look at what the Baja racers use. Those guys have big $$$ motors and they need to make it to the end of the race. You can't do that with a dusted engine.
Uni is a good filter also.
You can't be lazy with either.
All the Outerwears does is catch the stuff that is bigger than the mesh of the nylon, and lets the littler stuff just sails right through. The thing is that the real little stuff is what the gauze on the K&N is going to have the most trouble with.
The biggest problem I have with K&N is that it is very thin and pretty much ONE DIMENSIONAL. If something doesn't get caught on the sufrace, you don't have much behind it to back it up. With a foam filter, if it gets past the surface, there is still plenty of filter depth left as a backup to catch it.
I do have a K&N on my truck, but it only occasionaly sees off-road use, and I run a foam wrap (Air Force Filter, sold by K&N!) on it just for some added security.
cody500ho
14
08-14-2015 05:03 PM
