300EX TIP
Old Oct 14, 2000 | 06:17 PM
ex_master's Avatar
I just got my new tires put on the rims today. Bearclaws and front maxs the fonr tires work excellent but the rears make me loose too much power does anyone have an idea or cheap mods i can use to get my power back??? Oh Yeah heres the tip NEVER PUT BEARCLAWS ON AN ALMOST STOCK 300EX!!!
Old Oct 14, 2000 | 07:17 PM
300exSTER's Avatar
100$ says most of the people say change your sprocket...so i think that would be the best/cheapest way to get the "torque" back
Old Oct 14, 2000 | 07:22 PM
94DGblaster's Avatar
if you change your sprocket you will lose a lot of top end.
like 8mph probably.
I'd say sell the tires, or mod it.
with a pipe, cam, high comp piston it might turn them better.
Old Oct 15, 2000 | 11:37 PM
derrick's Avatar
If the tires are taller then just go down a tooth on the front sprocket. It will be good as new and it won't affect your top speed with the taller tires it will be just like it was before you messed with it.
Old Oct 15, 2000 | 11:56 PM
luckywilson's Avatar
Cheap trick' big gain in torque. If you are using a DG RCM header that has the long snout from the head that goes out about 6 in. then back. Cut 3 in. out of each side of the snout to shorten it. Then weld it back togather.
Old Oct 16, 2000 | 08:44 AM
skull's Avatar
I had spidertracs on my 300ex and found them to have to much traction. I could not get the rear to break free and slide. I sold them and bought some bandits. I love 'em you can do anything you want with them, but they are a little heavy.
Old Oct 16, 2000 | 10:33 AM
mojaveaddict's Avatar
listen to derrick
Old Oct 16, 2000 | 11:16 PM
puddding's Avatar
bit of road work
burn outs
shes all goooooood......wear em down about
smaller front sprocket......
they are 4ply too?......oem hondas tires are 2ply.......heavier
Old Oct 18, 2000 | 09:07 AM
Madmike101's Avatar
skull, when you say they are a little heavy. Are you losing any noticeable power in hill climbs and such? I am seriously considering bandits for this spring and I am looking for some good field testing results. What width are you running and are you running the 6 plys?
Old Oct 19, 2000 | 02:18 AM
skull's Avatar
madmike,
no I did not notice any loss of power. Im using the 4 ply 20/10/9 size.
these are perfect for me and the kind of riding I do. but there is one place that we go riding about once a year that is pretty wide open, thats why Im going to get a 14 tooth sprocket before going next year. most of the trails we ride are tight, and the smaller size tires work great, get me lots of low end torque.
I never noticed they were heavy untill I got my paddle tires. my paddles feel like they are about 5lbs less each. there is lighter tires out there, but a lot are made for racing like the razrs or holeshots. those tires are great, but made of a softer compound so they will wear quicker.
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
Wiley wolf
Sep 7, 2015 08:32 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
