Moose Plow lifting type???
I would have to agree with Rubeman. You would be better off with a winch. Consider this: If you get stuck while plowing snow, which will happen from time to time, you can pull the pins off the plow, unhook the winch cable and usually back off of it (the plow is what gets you stuck most times). Once unstuck, you pull out the winch cable, hook it back to the plow, and pull the plow out of the snow bank. These plows are not easy to manhandle in the snow.
Just my 2 cents.
Just my 2 cents.
I've got the EZ lift and a winch. Used the plow both ways and while it's not cheap, IMHO I have to say the EZ lift is a great product. I prefer it over the winch, because it has a spring-assisted range of travel that really helps over un-even surfaces. It's faster and gives me quicker height control with a "feedback feel", helping when I need to shave a layer at a time.
TheATVSuperStore.com
TheATVSuperStore
09-09-2015 07:43 PM
