Disapointed in Rocky Mountain
exbob-I suspect you may have gotten hardware for the wrong year. Call FMF and get it replaced. Honda may have varied some hardware from year to year, or your bike may have some aftermarket changes.
I had the same FMF setup on my 300EX, and absolutely no problems with fit or anything else! Never had a problem of any kind with RM either!
Been trying to remember when I put mine on.Did you check the other bolt in the grab bar?I used the one farthest back and If I remember right the stock bolt that mounts the factory muffler is bigger in size.Remove stock muffler and Put that bolt back in and pull the other one out.
Originally posted by: CeeCee
I had a problem with RM a while back. I had ordered some DD's on some ITP wheels. RM sent me the right tires all mounted on the same offset wheels. Then I had to send the wrong wheels and tires back and wait for the correct wheels and tires to arrive.
They should have done it right in the first place. I have ordered other things without a problem.
They seem to send everything out on offset rims, even if you tell them not too....
#15
yeah i check eveything it says my quad and i didnt mess up with the numbers or any thing and i know its for the wrong quad cuz nothing fits like the header is way to short for it to reach and there is no way for it to reach around to the exhaust port, and bolts dont fit or anything so im just going to send it back to them and cancel it and order it from a local shop and hope it gets right
#16
before you send it back,Did you read the installation instructions.The header pipe does not wrap around the frame like the factory header.It turns before the frame tube.The rear mounting bolt goes into the grab handle bolt that it farthest to the rear not the one that the factory bolt was in.Hate to see you send it all back and reorder just to get the same exact thing back .
#17
maybe the pipe manufacturer didn't include all the parts. I would not blame Rocky mountain. It's tough to handle thousands of orders and get every single one perfect. But I do know how you feel also. You get so pumped to ride with a new part and it doesn't fit.
#18
#19
That sucks.Just thought I would ask.I know when I first held mine up I didn't think it was right either.Definitely and fmf foul up if the package was labelled wrong. but I am sure Rm will make it right.Did you call them?what did they say?I just recieved my order from them today.3 seperate boxes and everything is what it's suppose to be.
#20
Yeah i did call them and they said that for me to return it and that they will check it out so im just going cancel it and i ordered it from a local shop that i know real well so it all good but thatks for all the repleys i really apreciate it.
THNX ROB......
THNX ROB......
Cantbuytime
Aug 17, 2015 06:33 PM
