Initial Maintenance
Old Aug 3, 2005 | 11:23 PM
tdagan1's Avatar
Default Initial Maintenance
Just got a 2005 Rancher. Someone told me that with the initial maintenance that i should have the valve clearance adjusted. Is this a high priority or would just oil change be sufficient.
Old Aug 4, 2005 | 01:21 AM
snowbuster's Avatar
Nooo. You need to adjust/check more than just your valves. Everything that could go wrong from manufacture defect will most likely happen in the first few hours of use.
Old Aug 4, 2005 | 02:00 AM
tdagan1's Avatar
Thanks for info
Old Aug 4, 2005 | 02:07 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
On a new machine, I change my engine oil and filter, and differential oils after just an hour or so. This gets the metal flakes out of the engine and diff right away. I change engine oil and filter again at 10 hrs. At 20 hrs. I switch to an ester synthetic engine oil (Maxima Extra) and Mobil 1 gear lube (75W90) in the diffs. Do a valve adjustment after about 20 hours.
dannytas
Sep 26, 2017 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
caveeagle
Sep 19, 2015 01:20 PM
Sep 17, 2015 03:06 AM
braap123
Sep 7, 2015 12:58 PM
