Tight Valves? grinding noise?
Old Aug 8, 2005 | 09:43 PM
ixRAZORxi's Avatar
Default Tight Valves? grinding noise?
What do tight valves sound like. I set my valves on the rancher at .006 at tdc. They where way out probably .012.
I adjusted my rancher valves and the tapping is gone. I noticed a grinding sound coming from somewhere. It may have always been there I'm not sure (the valves were loud). It's a low rpm grind its not at the same speed as the engine. I thought it was the heat sheild at first but its not.
Clutch pulls good. If I turn the idle up it will lunge forward then roll back about an inch. Had no affect on the sound.I reset the idle so the clutch doesn't burn. Transmission works perfect.
Engine is strong no smoke.
I can't decide what it is. Any ides.
Old Aug 8, 2005 | 09:45 PM
LittleBill's Avatar
give the valves a couple hours they go right back to making noise, i've done mine 3 times only for them to make noise within 40 miles, don't worry u won't hear the grinding soon
Old Aug 9, 2005 | 11:42 AM
ddrumman2004's Avatar
When adjusting valves, it's better to err towards a loose setting than a tight one. I have known some motorcycle engines and one auto engine in particular that if you set the valve clearance too tight, the valves will not seat properly and could possibly burn.
If they are ticking, you know the valves are seating.
My 4 cents worth.
Old Aug 9, 2005 | 12:10 PM
Malkuth's Avatar
Tight valves usually don't make noise, which is alot worse then having loose ones.
Don't worry to much about the Chattering, Hondas are known for it. Its annoying as hell, but nothing you can do.
Just as long as you were not using a MM Feeler guage, you should be alright? Where is the Grinding coming from?
Old Aug 9, 2005 | 03:10 PM
ixRAZORxi's Avatar
I set them at .006 inch /.152mm
Motor runs perfect and has no knocks or ticks. I can't figure out if this grinding sound is internal or not. Its very low and only happens once every second or so. Its not something internal spinning 1000's of rpms. I think its clutch related.
flyin-lowe
Dec 1, 2017 03:18 AM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
kbazzy
Sep 26, 2015 11:26 AM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
