Lights Problems
Old Aug 14, 2005 | 08:13 PM
Sinbad's Avatar
Default Lights Problems
My two lower lights on my 2001 450ES will not operate properly. It appears to be a non-contact problem at the bulb connections. For the life of me, I can't fix this. If you play with the spring loaded connectors, the lights come on but if I let go, they go out again. Has this happened to anyone out there? How did you fix it? [img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Aug 15, 2005 | 01:09 AM
LittleBill's Avatar
my issue was on a trailer that had spring loaded bulbs, some how the connectors on the spring wore down, i sodered the points up so the spring pushed harder against contacts and fixed itself
Old Aug 15, 2005 | 07:04 AM
Sinbad's Avatar
Thanks! I'll try that this afternoon and let you know how I make out. Did you solder the bulbs or the socket?
skinnyr6
Aug 25, 2023 02:18 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
