Mud tires for Recon?
Recoman
The Goodyear stock tires that Honda put on the Recon are not that great of a mud tire. They should have put Titan 489's on as stock tires. My wifes trailboss came stock with the 489's. I am really impressed with the mud traction they provide. Anyway, go to www.treadepot.com . They have a great selection of mud tires and it appears they have some in the 24 inch size. Hope this helps.
We put Sur Traks on our recon & it makes a huge difference. The only problem is they about 1/8 to 1/4 inch shorter than the oem tires. The tractions makes up for this. Also, if you reverse the directions you can run them in snow, haven't tried that yet.
I noticed the same thing as snowshark did with his sur tracks they are just a little bit smaller than the oem but the work great.
When mine go bad I will most likely buy the sur tracks again.
1998 honda recon surtracks mounted on itp aluminum
ids2 suppertrapp exhaust and k&n
According to their web site http://www.itptires.com/blackwater.html
The Blackwaters come in 22x12.5x9 which would be same height and rim diameter you have now but just 2.5 inches wider. I am thinking about getting them for my Recon.
