2005 rubicon winch istallation
Old Aug 20, 2005 | 10:58 PM
mark1610's Avatar
Default 2005 rubicon winch istallation
Can someone help me out with a couple questions I have on installing a winch on my 2005 rubicon? will I need to install a larger battery or will the stock battery do the job? Are there any fuses that will need upgraded to a higher amper. I have not ordered the winch yet but I am looking at putting a warn 2.5 ci on the machine. I think this should be plenty of winch for a 600lb machine.Has anyone installed a warn winch on there rubi ? and if so was there any cutting of the front skid plate to get it into place. It would be great if someone could post a photo of a 2005 rubicon with a winch installed.
Thanks, mark
Old Aug 20, 2005 | 11:10 PM
Rogan's Avatar
Just picked up an 05 Rub yesterday with a 2.5 Warn and no one said anything about needing a diffrent battery. I had the dealership to install but it looks pretty simple to me. Seems running the wires will take the most time due to the tight space from front to rear. I'll take some pictures as soon as I can and post. If I had to do it over I'd bought mine on-line and installed myself. Mounting the winch base looks simple to me and I didnt notice any trimming on the skid plate.
Old Aug 20, 2005 | 11:25 PM
mark1610's Avatar
Rogan thanks for the fast reply. I found a great picture of the mounted winch on the warn web site and it looks good on the machine. If you take some photos of the rocker switch and the battery area that would help me out.
2005 rubincon
2004 recon
Old Aug 21, 2005 | 05:01 PM
mark1610's Avatar
Well I ordered my new winch today. I ended up going with the warn 2.5 ce. this winch has a mechanical break system so it cost alittle more than the ci modle but it is whats recommended for use with a snow plow so I'll be ready if I ever put one on.
Old Aug 23, 2005 | 11:59 AM
Rogan's Avatar
Here is a link to some images. I can email them to you if you need a couple close ups.
http://www.forumpictureprocessor.com...p?gallery=1012
Old Aug 23, 2005 | 01:46 PM
dodge4ever's Avatar
I installed a Warn 2.5 ci on my 05 rubi. one ov the biggest pains in running the wires also removing all of the front skid plates. sorry i don't have any pics yet but a look at rogans will give you a good idea. Mine is similar except i mounted the control unit inside the storage area for more protection from water. then i drilled about a 1" hole directly from there to behind the battery to run the power cables then siliconed the hloes for a water tight fit. yes it does take up a lot of room in the storage bin but the only thing i geep in there is a roll of T.P.
Old Aug 23, 2005 | 10:14 PM
mark1610's Avatar
Hey Rogan thanks for the photos. I got my winch today and had it on in about an hour ,next comes the fun part of wiring it up. It sure looks good on the machine. Hope to try it out at deer camp this year to host some deer up on the buck pole. Hey dodge4ever I was surprised on how much of the front end that I had to remove too. Not sure where I'll mount the control unit yet I got to look it over first to see what I can come up with. Thankyou both for the help.
2005 RUBINCON
2004 RECON
2003 TTR 125
2003 KLX110
Johnny Mac
Aug 15, 2019 03:13 PM
salixair
Nov 3, 2015 08:25 AM
cboler9
Sep 24, 2015 08:35 PM
patrick.oc123
Sep 15, 2015 02:45 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
