changing 450 r handle bars
Old Sep 13, 2005 | 10:30 PM
YFZracer88's Avatar
Default changing 450 r handle bars
yea i have a 450r and i was looking at the handle bars and i was wondering what u guys do with the on/off switch after u put after market bars on
Old Sep 14, 2005 | 12:26 AM
whiteflash1's Avatar
the keyswitch? my friend has pro taper bars and the key switch fits on them. if the switch doesnt, you can rewire it so it doesnt need a key, or cut a hole in your plastics and put it there.
Old Sep 14, 2005 | 09:43 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
http://www.tagmetals.cc/
TAG METALS T2 KIT! You can get them in a 450R bend (same as CR-HI I think???), with a slick little mount. The mount comes with a plate that holds the key, little light, and the tank vent tube.
The bars are a little lower than stock, for a much improved riding position. Very pleased with mine!
Old Sep 14, 2005 | 10:38 PM
YFZracer88's Avatar
how would u rewire it so it doesn't use a key.
Old Sep 14, 2005 | 11:04 PM
Red Rider
On a kickstart bike, the key grounds the spark when you turn the key off. So I think you just seperate the wires, and interupt the ground???? Then you can just kill it with the kill switch, when you need to turn the motor off.
But, with these bars you can keep the key, so your little brother (or your kids) won't be joyriding on your machine.
Old Sep 15, 2005 | 10:24 AM
TL450R's Avatar
I cut the keyswitch out and mounted it on the frame on the lieft below the gas tank, that way i still keep the key for security, no one knows where it is. i mounted the light on the bars
Old Sep 15, 2005 | 10:26 PM
YFZracer88's Avatar
alright thanx guys ill try to do that with out screwin anything up.
Old Sep 15, 2005 | 10:28 PM
YFZracer88's Avatar
oh hey one more thing where did u get ur hrc kit and how much was it
Ashley S
Feb 18, 2024 08:56 PM
HYS
Aug 18, 2015 12:28 PM
1966F100
Jul 14, 2015 12:19 PM
coolguy420
Jul 9, 2015 09:54 PM
