new 300ex smoking
Old Oct 30, 2005 | 07:17 PM
Opteron's Avatar
Default new 300ex smoking
Just like my specialty, cars. You gotta seat your rings. Don't baby it during break in.
Old Oct 30, 2005 | 10:08 PM
LittleBill's Avatar
Jimmy as others have said, a hard but not brutal break in is the best way to go to seat the rings, its why i asked you the question without giving an indication as to what the correct answer was, if they won't fix it, start riding it a bit hard mabye u can get it to reseat but i doubht it
Old Oct 30, 2005 | 10:30 PM
JimmyHoffa's Avatar
Thats kinda sad. All of that makes perfect sense. Too bad I hafta wait like 50 years until I rebuild it to get my power back. Also, I may have discovered the cause of the smoke. I just need to know a fact. How much oil does it take to make smoke? I washed my baby today and during my routine checkup of the intake system, I discovered a thin coat of oil on the inside of the intake tube. This was probably from when I upended it on a wheelie. Is this enough to cause smoke? Just curious, because I drove it all around and let it warm up and it wouldn't smoke anymore after I cleaned the tube. (Plug still reads like a dream engine-I was under the impression that when you're burning oil there will be deposits on the porcelain)
Old Oct 30, 2005 | 10:34 PM
JimmyHoffa's Avatar
I think I'm taking it next weekend so I'll see if it gives me the blue cloud again on the trails.
Old Oct 30, 2005 | 10:36 PM
  #15
Chris142's Avatar
There is a crankcase vent that brings blowby gasses to somewhere before the carb to prevent them from being blown out into the air.
If there's alot of blowby past the rings some oil will be brought with the blowby gasses. The oil will then be sucked back into the engine.
As a last resort I would warm the thing up then ride it like you stole it as long as you can hold out. Get the cyl pressures up and maybe the rings will seat.
Old Oct 30, 2005 | 10:38 PM
  #16
Opteron's Avatar
I agree with Chris. Good chance that will work IMHO
Old Oct 30, 2005 | 11:14 PM
  #17
JimmyHoffa's Avatar
Good deal. I can hold out for quite a while.
Old Oct 30, 2005 | 11:18 PM
  #18
JimmyHoffa's Avatar
If i have about 30 hrs. on it is that way to much to be able to seat the rings? Or am I just loading my engine for no reason...
Old Oct 31, 2005 | 01:32 AM
  #19
LittleBill's Avatar
thats a high number, but it never hurts to try, also didn't know had oil in the intake track, that could also be a problem, just follow what we said, and let us know the outcome
Old Oct 31, 2005 | 09:52 PM
  #20
Honda919Rider's Avatar
Have or do a compression and leak down test.
These will identify if the problem is with the rings, valves or something else.
I agree with taking it to the dealer. Just be sure you have your maintenance documented well, as it makes it a lot easier to file a warranty claim.
Good luck!
