Speed of an 86' 250r
Old Nov 7, 2005 | 11:00 PM
SpeedDemon13's Avatar
Default Speed of an 86' 250r
How fast will an 86 250r go stock? How fast will it apx. go with a fmf pipe, twist throttle, new topend, 39mm carb?
Old Nov 7, 2005 | 11:23 PM
1BAD250R's Avatar
Probably in the 70-72 range stock. As far as with the mods I couldn't tell you for sure. But to increase top speed, all you need is a gearing change.
Old Nov 8, 2005 | 12:51 AM
twentycharacters's Avatar
the 86 model has a taller 6th gear than the rest of the years. it is slightly faster overall topend, but it may bog out without a little more juice. mine has a rad valve, boysen reeds, fmf pipe, and a uni air filter, stock carb (not sure what the jetting is since i bought it used from a guy in cali -runs fine here down in south, so i didnt change it) and it will hang right with a stock raptor.
with a bigger carb, yours should be a little faster than mine if the topend job was done right. but yeah if you want more topspeed go up one on the front or down a few on the back sprocket. i always thought the gearing of mine was good and wish the newer sport machines still offered 6 speed trannies.
Old Nov 8, 2005 | 12:56 AM
Jibrille's Avatar
I GPS'd mine at 70mph.
Mine has a Duncan FatBoy 2 exhaust, UNI filter, Boyesen Reeds, Shaved head, port and polished. Can't remember my gearing either, sorry.
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Sep 23, 2015 02:41 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
