Hauling 400EX on end???
Old Nov 22, 2005 | 12:00 PM
oldturtle's Avatar
Default Hauling 400EX on end???
Just wasted 15 min searching for answer. Do I need to drain oil tank and oil in engine before standing up for haul. I will drain gas tank. I'm sure this has been answered hundreds of times. Thanks
Old Nov 22, 2005 | 12:36 PM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
Just turn the fuel off and stand it up. I've done it before and never seemed to harm anything.
Old Nov 22, 2005 | 02:27 PM
hondabuster's Avatar
Its a bit diferent hauling on the grab bar, as opposed to just having it sit in the garage.
Make sure you take out the battery, all the jiggling around and bouncing, could shake all the crap at the bottom of the battery case, and now send it to the side.
If the gas level is low enough, it shouldnt come out the cap vent, but if its posible..drain the tank and float bowl, and refill when you get there.
Old Nov 24, 2005 | 01:08 AM
URCRAZY's Avatar
Well I hauled mine in a back of a nissan with DS 650.. I had my 400EX on end almost on the bar with the front tires over the cab, with the frame resting on the cab,,(ouch the cab got dented) and the DS right up against my rear tires.. I had my rear fenders off.
I and a friend drove it this way from Seattle to Arizona. I turned the gas off and that was it.. But before starting it I let it sit for a while, and I cranked the engine over before starting it.
It was wild to see that in a back of a old Nissan pick up.
badgerboy1
Sep 26, 2017 06:11 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Sw00p
Sep 24, 2015 02:50 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
