36mm pj jetting
Old Nov 1, 2000 | 12:56 PM
steve250R's Avatar
I got a 36mm keihen pj carb for my '86 trx250r and i was wondering if anyone knew a good starting point for the jetting. ie; what pilot and main to run and i need to know what needle to run to. For mods i have a fatty pipe and a rad valve.
thanks,
steve
Old Nov 1, 2000 | 04:57 PM
trapperb1's Avatar
If you have a stock air box with stock filter, the stock main jet for a 86 R is .150. If you want to start there, this could be a good place. Go up 1-2 sizes for each mod; pipe, go up, opened-up air box, go up, etc. So, now, if you have a pipe, reeds, start around a .155. You can keep going up until it just "blubbers" on the top-end and then step down one at a time until it stops.
Start with the needle in the center or notch #3. Make sure your throttle cable is adjusted to let you have full use of the carb. Make sure your air filter is clean and you start with a new plug. I prefer the B8ES or the B9ES. Good luck and have fun!
Old Nov 1, 2000 | 04:58 PM
retro's Avatar
Try http://www.carbparts.com/. They should be able to help.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
