Honda TRX 250
The TRX250 has a semi-automatic clutch. It has a traditional plate clutch and a centrifugal clutch. When you shift gears a linkage connected to the shift shaft disengages the clutch. That is how I do wheelies on them. Hold the shifter up and give it some gas. Let off the shifter and the clutch engages pulling the front wheels off the ground.
