Rear sprocket on '03 400ex
Yes, I have tried all the combinations on the 400ex. Don't lower the rear sprocket. It won't pull it in 5th gear unless you are going down hill. The $30 bucks would be better spend on a case of beer.
Originally posted by: reconranger
Going to a 4:10 in the Suburban is a LOWER gearing, and should give you MORE LOW END. I would do it in my Suburban, but I have a 4wd so the gearing change gets quite a bit more complicated (I presume yours is a 2wd???)
The change you are proposing for your quad would be a HIGHER gearing, so you could expect more top end but at the expense of low end.
I already paid for the stuff might as well try it. It comes next week. I noticed my old signature and I had a 44T on my old 250R Atc and went to a 42T and I didn't notice much. Different game?
#15
Confused. As the others have stated, it give you more top end. Please explain
#16
Originally posted by: DesertBum
What's your opinion? removing 2 teeth doesn't sound like much. I see you also have a 400ex. Stock? Anyone done this with a opinion?
#18
As for the 660 Raptor, you will get many different opinions on that one. Just start reading and doing a few more searches on the subject and look for people that have owned one and gotten rid of it. Not trying to start a big hoopla here because I'm sure many people love their 660 but just read more about it first and make your decision.
#19
Also, if you are still going to run the stock length chain on it, I would guess you would run out of chain adjustment. Maybe or maybe not at first, but when your chain started to stretch after time. Just another small consideration.
#20
Thanks. You did explain alot. One reason is not to shift as much. The trails here are mainly flate, more MX style I guess. I am rarely in 5th mainly in 2nd pinned through 4th pinned. I seemed to shift a lot when I am ridding.
I also did order a 90 length x-ring chain with the new sprocket to avoid the adjustment you stated.
