2005 foreman 500 wont start
Old Jan 1, 2006 | 01:24 PM
twofingerdoug's Avatar
Default 2005 foreman 500 wont start
Hi guys, got a problem with the foreman 500, it will not start. Spark plug is clean, good gas, everything is turned on, just wont start, it does turn over but thats it. Any suggestions would be appreciated.
Old Jan 1, 2006 | 01:32 PM
RideRedOrStayHome's Avatar
does the spark plug have a spark and i no u said every thing was turned on but is the gas on
Old Jan 1, 2006 | 01:44 PM
Gas is on, I've only ridden it about one tankfull of gas. This is the 2nd time this has happened, the first time it started about 2 days later when I tried it. It has a mind of its own.
Old Jan 1, 2006 | 03:18 PM
hondabuster's Avatar
How does it start once its warm? Is it just having trouble when its cold?
Youre using full choke to start? Primer ?
Will it start using the rope?
When it does fire up...does it sound plugged up, or runs clean and smooth? any smoke from the exhaust?
It could be a misadjusted mixture screw(too lean), or the intake valve is too tight, or just a starting procedure. Have you tried holding the throttle at a steady 1/8 to 1/4 open, while cranking? It should fire up right away.
Old Jan 1, 2006 | 10:01 PM
oldturtle's Avatar
I don't know about the Foreman CV carb but on all regular slide motorcycle carbs the pilot jet will often become plugged just from sitting for a few months. So if the quad started easily before storage and then 2 or 3 months later it won't start then look at pilot jet. Just because you poured fresh gas on top of what was in there does not insure the gas in float bowl is good or that pilot jet is clear.
Old Jan 3, 2006 | 01:21 PM
sporter's Avatar
My 2005 Rubicon won't start unless the choke **** is held all the way out regardless of the outside temperature.
Old Jan 4, 2006 | 06:47 AM
dzzy's Avatar
Try draining the carb. Turn the gas off, find the flat blade drain screw at the very bottem of the float bowl. It will be facing out at you on one side or the other. Turn it out about a turn and you will see gas running out the hose that goes down under the machine. When it's done running out, turn your gas back on and you're ready to try to start it.
neilbedwell
Nov 10, 2018 11:02 AM
Land_shark1
Jul 10, 2015 12:53 AM
Marc Parish
Jun 26, 2015 09:37 AM
neilbedwell
May 31, 2015 11:11 AM
1000gade
May 27, 2015 12:37 PM
