Draining Air Filter Box.. Is this normal?
Old Feb 4, 2006 | 08:06 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default Draining Air Filter Box.. Is this normal?
I am **** about warming up my engines so I doubt that pertains to my situation, but that does make some sense being a dry sump engine. Like I said, mine use to do it all the time and now has mysteriously quit........
Another issue about the overoiling the filter theory comes to mind. I oil all my filters the same on all my quads, so why don't all of them have oil in the airbox and not just the Rancher if that's the problem??? It just doesn't make sense in my case.
Actually as I recall, I have had oil occasionally in the airbox of the Recon and 250EX, so I think it has more to do with the location of the breather (external on the outside of the air filter), than anything else???? The higher end Honda sport quads have their breathers attached directly to the air intake boot between the airbox and the carburator, so if you were sucking oil on one of those you are less likely to notice it.
Old Feb 4, 2006 | 05:16 PM
quad2xtreme's Avatar
I still have 2 400ex quads and had 1 other. I've had crud in the bottom of the filter from all of them. When I used blue filter oil, it was blue. When I switched to Amsoil, it is now clear or black depending on how long I wait to clean it up. I've had oil drip down from the filter and fill the clear thingee before I've even road. I don't think anyone said this is the one cause. I agree with all the posts. It could be this, it could be that. Check them all out and see what your situation might be. I am willing to bet my house that mine is from the oil filter...
/Jon
Old Feb 6, 2006 | 02:21 AM
freedomintheskies's Avatar
Sounds like you may have had the oil level a bit high.
Just keep an eye on it and only check it after you warm it up. The Honda dry sump system is prone to "flowback", so the oil level MAY appear to be low if the engine has sat for any length of time.
COFatboy
May 2, 2020 12:06 AM
Cummins Driver
Sep 11, 2019 01:22 PM
kester_holmes
Sep 10, 2015 08:27 AM
STEVE71157
Aug 29, 2015 07:33 AM
hondarider1234
Jul 21, 2015 11:53 PM
