tire diameter
Old Feb 6, 2006 | 01:04 AM
Tass's Avatar
Default tire diameter
I am after a little general information on tire diameter. I have already received quite a bit of valuable information from this forum and hope to get some more. I suspect the tires on our Rubicons will need replacing in a short time. With 4 psi pressure the diameter is approx 25" (25x10x12). A friend just installed a new set of Mudlites on his Rubicon and with the same pressure they are about 3/4" less in diameter. It would seem that to maintain the present gearing which I find ideal (or perhaps go a little higher which would be fine) I would need to go to a 26" tire or perhaps to the XT or the XTR in order to maintain the diameter. A friends 25" Dirt Devils measure almost 26" so perhaps that would be an option also. Has anyone done any actual measuring of diameters or perhaps is aware of charts which list the information? Quite often advertised numbers are only close at best........Thanks.........Tass.
Old Feb 6, 2006 | 01:33 AM
fixitman69's Avatar
It is hard to find actual outside diameter sizes advertised in catalogs or on parts websites, but if you go to actual manufacturers websites, some of them will list actual outside diameters.
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
