recon carb problem, help
Old Feb 11, 2006 | 02:24 PM
444XCrecon's Avatar
Default recon carb problem, help
ok,i stood my recon up on the grab bar and a good bit of gas leaked from the carbuerator into the air box,how can i fix this?
Old Feb 11, 2006 | 05:07 PM
1988TRX250R's Avatar
Don't stand it up on the rear bar!! If your looking to prevent this from happening, shut the fuel petcock off. Then drain the carb float bowl w/ the screw on the bottom of the carb. Using a flat blade screwdriver, just loosen the screw and wait until all the fuel drains out. If the machine won't start after setting it back down, assuming you turned the fuel back on, it may be flooded. Hold the throttle WFO while cranking and it will clear out after a few seconds.
Old Feb 12, 2006 | 07:32 PM
reconriderman's Avatar
i have a honda recon and i stand it on its back rack all the time and its fine
Jun 10, 2015 12:45 AM
'86 TRX125
Jun 6, 2015 07:43 PM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
