Battery Draining Honda Four Trac 300
Old Feb 12, 2006 | 09:16 PM
DrHunter950's Avatar
Default Battery Draining Honda Four Trac 300
Did anyone hear of a solution to the Battery draining on a 1995 Honda Four Trax 300. Battery takes a charge then when left for 2 or 3 days it drains and wont start. battery was replaced in spring. Someone told me there is a link that can be put in.
Old Feb 12, 2006 | 10:13 PM
recon99's Avatar
First you have to narrow the problem down to the electrical system or the battery itself. Take the battery out or disconnect one of the terminals, and charge it up. Let it sit for 2 or 3 days, hook it back up, and see if it starts or if it's dead. If it starts you have a parasitic drain in your electrical system. My guess though is that it won't start up when you reconnect the battery, and the problem is a bad cell in the battery.
Old Feb 12, 2006 | 10:45 PM
hondabuster's Avatar
If you have a voltmeter, you can check for the amount the drain is.
Turn the key to off, and dont turn it back on during the test, or you could smoke the meter.
Disconnect the negitive connection on the battery, and put the meter from the battery terminal to the cable (in series). Start the meter in the highest setting for amps, and work you way to the lowest setting. I dont have the specs handy, but it seems to me, if its under 1 miliamps, its in specs. And if thats the case, have the battery load checked.
Its not unheard of, to have a new battery take a dump this quick.
Old Feb 12, 2006 | 11:56 PM
Thanks, I put a new and second DIE HARD in, seems I have no luck with them but there may be a drain that I cant find. I did try to disconnect the battery and charge it but it runs down within 2 days even if i dont use the machine.
Old Feb 13, 2006 | 12:00 AM
recon99's Avatar
but if you disconnect the battery for a few days does it still drain?
Old Feb 13, 2006 | 12:04 AM
That I will try to charge it and leave it. Hope it holds the charge. Cant be buyong one every 7 months. TKS
Old Feb 15, 2006 | 01:41 AM
1988TRX250R's Avatar
Where are you getting your batteries from? If they don't know what they're doing, the batteries could be prepped wrong and won't last very long.
There should be no amp draw w/ the key off on that machine. There is no clock or anything w/ a memory that would require battery voltage w/ the key off. My Fluke meter has a 15 amp fuse in it. I can turn the key on w/ the meter in series w/ the negative cable but if I hit the starter button I'm lucky if it just blows the fuse. W/ the key on, there will be a several amp draw. W/ the key off, it should be zero.
skinnyr6
Aug 25, 2023 02:18 AM
Sjrpp
Jun 2, 2019 07:25 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
