400ex chain ajdustment
Old Nov 11, 2000 | 07:13 PM
250rampage's Avatar
I was trying to tighten the chain on my 2001 400ex, and in the manual it says to loosened the axle carrier nuts, and spin the tightner wheel to tighten the chain. I got all the carrier nuts loose, but couldn't get the wheel to spin, and even bent the allen wrence tryingto use it for leverage.
Old Nov 11, 2000 | 09:29 PM
HondaLuvr303's Avatar
I don't know what could be wrong, maybe you didn't loosen the bolts enough. It should be fairly easy.
Old Nov 11, 2000 | 09:36 PM
pudjumper's Avatar
Take a hammer and lightly but sharply tap around the bearing housing. This will should loosen the adjuster. Do not swing hammer as if you were driving 16 penny nail for you might damage the housing.
A Shock adjuster wrench works better than that short stubby allen wrench.
Old Nov 12, 2000 | 07:48 AM
01TRX400EX's Avatar
Being brand new it should turn easily with all 4 of the allen bolts loose. When I recently did mine you could almost spin it with your fingers... Are you sure that all 4 clamping bolts where loose enough?
Leo
Old Nov 12, 2000 | 12:08 PM
quad1man's Avatar
You're gonna laugh.... Put it in neutral...
Old Nov 12, 2000 | 12:44 PM
250rampage's Avatar
No, I had was in Neutral, but I did finally get it today, I had to take the axle carrier nuts completely out before the wheel would move, and then I turned it with a extra long allen wrench.
mrtidy
Feb 3, 2016 05:00 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
