400ex Help!!!
I just bought a new frame because was told by a local dealer that my frame was bent. so after the long process of frame swaping i found out that the new frame did not fix my problem. my problem is that the quad does not sit level in the front. when i pick up on the front bumber, the left tire drops down about 2 inches lower than the right side tire. but when i pick up on the rear subframe the front end levels out. the shocks are fairly new, just bought last year, and only have maybe 40 hours on them. i was wonderin if anyone had any ideas what my problem is. the quad drives straight. i just don't like having more pressure on one shock than the other. thanks for the help
