trx 90 rear tires
Old Feb 10, 2002 | 08:34 PM
tb4x4's Avatar
can anyone give me a place to buy rear tires for my kids 1998 trx 90
the size is 19x8x8. i have searched the web but have no luck with that odd size
thanks
Old Feb 10, 2002 | 10:25 PM
jaybeecon55's Avatar
Sound advice there. "Hey, watch this........"
I searched all over about a year ago when we needed new rear tires. The only place I found with that size was to go through Honda and get the stockers.
Jaybee
Old Feb 10, 2002 | 10:49 PM
I just checked my records. It was longer than I thought - May 2000, two rear tires from Honda went for $78.
Jaybee
Old Feb 11, 2002 | 10:14 AM
95wolv's Avatar
I looked into tires when my son needed rears for his LT80, 19x7x8,I found the Kenda Scorpion at 20x7x8 was so close to stock, there was almost no difference. Look into some of the 20 inch tires,you will find a lot that are almost the same,if not shorter,than the factory. I even saw one guy running 20x11x8 holeshots on his kid's Honda 90, he said it gave great traction, and didn't seem to hurt the power,but they did seem a little wide. Anyway, check it out, you should be able to find something real close. Try Rocky Mountain ATV, or Tread depot, real cheap tires.
Old Feb 13, 2002 | 06:01 PM
nacsracer40's Avatar
If you dont mind running a smaller tire on the back, try the 18-9.5-8 turf tamers with custom grooving. the grooving supposedly saves weight. We also bought some douglas aluminum rims too, but thats just because mine were beat up pretty bad. So far the tires have held up very well with a full year of racing and riding on them. they still have the dimples in the treads but i'll probably flip them around for this race season. I am very impressed with the tires compared to stock.
~BaTmAn~
'86 250r
LRD national motor/pipe/silencer & Hammer motor, AC pro pegs/bumper/grab bar, maier dark blue plastic, Nac's Racing graphic kit/seat cover/bar clamp/bar pad/brake block off/case guard/mud caps(beadlocks), marshall radial fronts on douglas .190's, holeshot mx's on douglas/champion beadlocks, Tag bars, leagers a-arms/swing arm, LSR axle, anti fade lock nut, Elka & PeP rear shock, Ekla front shocks, GS Racing wireharness/chassis bolt kit
'95 CR125r
'01 Raptor
'98 trx 90
Old Mar 3, 2006 | 08:11 PM
trxfourfiftyr's Avatar
Default trx 90 rear tires
yo
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
Polaris5
Aug 29, 2015 09:11 PM
rcappie4
Jul 18, 2015 07:51 AM
rcappie4
Jul 10, 2015 04:54 PM
