400EX carb trouble.. NEED HELP!
Old Mar 9, 2006 | 11:58 PM
300exStroked's Avatar
Default 400EX carb trouble.. NEED HELP!
I've got a 300EX.. bought a 400EX carb with the flow mod with intentions of putting it on.. finally got around to it couple days later.. when i start it up it idled at about half throttle.. i just figured that the pilot jet was too big because it came off of a 440 or big 400 .. changed the pilot from a 50 to a 42.. and the main from a 200 or something down to a 142.. threw it back in.. still idled at about half throttle.. the float isn't stuck.. needle isn't broken or anything.. slide goes down and sits perfectly.. i tried seeing if there were leaks around the intake mani but were none.. threw the 300 carb back on.. worked like a dream.. something in the carb is messed up.. any suggestions please let me know.. thanks - adam
Old Mar 10, 2006 | 12:25 AM
Wolverine2003's Avatar
You'll probably have a hard time jetting a 38mm carb to run right on an engine that came stock with a 32mm carb. I'd guess you'll have to drop all jets quite a few sizes to get close, especially at idle. What are the smallest jets available for the 38? You might be better off rejetting the stock 32mm.
Old Mar 10, 2006 | 09:40 AM
450rking's Avatar
have you checked the idle screw under the carb?
Old Mar 10, 2006 | 10:23 AM
it is the 35.5mm carb off of the older years.. but yeah.. the air screw is backed out far enough that it isn't even touching on the inside.. i took the black plate off of the side to make sure
Old Mar 10, 2006 | 10:45 AM
Actually.. i just tried putting in a 38 pilot jet.. didn't work.. but i did happen to put the 50 pilot in my 32mm carb and it idles just fine.. in theory.. you would think that it would be fine.. i just got off the phone with honda.. told them what I had.. what was going on.. "uhh, it could be anything" I was like.. do you have any suggestions of what I should look for or try.. "no, like I said it could be anything".. honda is worthless anymore.. at least the one where I live.. they are always a bunch of douches when you try to ask them questions.. half the reason why i'm on atv connection
Reactant
Mar 30, 2022 02:08 AM
GregM
Jul 29, 2015 09:41 PM
metal249
Jul 24, 2015 01:00 PM
95wolv
Jul 21, 2015 12:25 PM
yambam13
Jul 4, 2015 01:49 PM
