recon brakes
Old Mar 25, 2006 | 11:02 PM
reconister's Avatar
Default recon brakes
I just got a 04 recon es and i can pull the brake lever for the front brakes all the way to the handle bar and it barely stops the front wheels. Do I need more brakes or is there adjustment
THANKS FOR ANY INFO
Old Mar 25, 2006 | 11:05 PM
1988TRX250R's Avatar
Remove the little red plugs on the front wheels to access the brake adjusters. There are two adjusters on each wheel. Tighten the shoes up to the drum and then back the adjusters off three notches.
Old Mar 25, 2006 | 11:09 PM
mykool61679's Avatar
if that dont work change fluid(should be clear, not gold looking)
Old Mar 25, 2006 | 11:13 PM
reconister's Avatar
Is the reason they arent working because my brakes are getting worn do I need new brakes!
Old Mar 25, 2006 | 11:22 PM
The shoes will wear down w/ use which is why you need to adjust them. When you remove the red plugs, check the brake shoe thickness. If there is still brake material on the shoes, adjust them.
Old Mar 26, 2006 | 12:08 AM
LittleBill's Avatar
when looking through the hole, make sure u don't see water and mud in there, if you do, the adjustment will do nothing, the brakes will have to be pulled and cleaned
Old Mar 26, 2006 | 02:32 AM
recon99's Avatar
The recon's brakes need to be adjusted regularly, but the shoes will be fine on a 2004. The original brake shoes were still on my recon when I traded it in, and it was 5 years old at the time. If you have the owner's manual look it up, it shows you how to adjust them.
Old May 26, 2006 | 04:59 PM
Cacheola's Avatar
You can only adjust so far. The rubber brake lines don't help. Upgrade to stainless lines lol.
The front brakes lick. They are merely adequate at best. Why do you need to stop anyway??
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
Jason Campbell
Sep 7, 2015 02:25 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
