HELP!! Honda Foot shifter Sticking :(
Old Apr 3, 2006 | 10:46 PM
cblcbn2000's Avatar
Default HELP!! Honda Foot shifter Sticking :(
I have a 2000 Honda trx 300 fourtrax 4x4 and when i shift up to the next gear the shifter hangs up about every other other shift. To get it back down you have to push it back down with your foot ITS DRIVING ME CRAZY!!!!!!Text[img]i/expressions/face-icon-small-confused.gif[/img]Text
Old Apr 4, 2006 | 07:35 PM
cblcbn2000's Avatar
Please HELP!!!
Old Apr 5, 2006 | 12:31 AM
1988TRX250R's Avatar
Its possible the return spring on the shift shaft is broken. Remove the clutch cover and inspect. Either that or the shaft is bent causing it to bind in the cases. Either one can be fixed easily.
Old Apr 5, 2006 | 01:07 AM
Sparky8370's Avatar
Every other gear-is always the same gears? Like always odd or always even. I'd get a repair manual and tear the thing down. Transmission work is not for novices though. I'd label everything and store it in the exact way it was removed. Since it's only every other gear I'd say maybe something in the countershaft.
Old Apr 26, 2006 | 02:25 AM
vd's Avatar
vd
Is the shifter bolt loose on the outside? or is inside the motor?
Old Apr 20, 2007 | 12:45 PM
robert023's Avatar
Mine does the exact same thing. Did you find out what was causing it?
Old Apr 21, 2007 | 07:16 AM
HondaMechanic's Avatar
none
Njrider1230
Jul 29, 2023 05:16 AM
peytonius
Sep 28, 2015 02:18 PM
Kodiak-vic
Jul 29, 2015 03:06 AM
Schneider
Jul 24, 2015 05:05 PM
timster911
Jul 13, 2015 01:57 PM
