white spark plug in 400ex
Old Apr 5, 2006 | 11:29 PM
OneWheelWheelie's Avatar
Default white spark plug in 400ex
im from canada so its still a lil colder wheather its suppost to be plus 10 tomorow
Old Apr 5, 2006 | 11:46 PM
Sparky8370's Avatar
Originally posted by: OneWheelWheelie
wats a plug chop ????? what would be fmf's website so if the plug is white i have to keep going bigger
It's when you run it at a certain range like :
1.) 0 to 1/4 (while driving) then shut it down-do not let the rpms down, hit the kill switch.
2.)1/4 to 1/2 (while driving) then shut it down-do not let the rpms down, hit the kill switch.
3.)1/2 to 3/4 (while driving) then shut it down-do not let the rpms down, hit the kill switch.
4.) 3/4 to full (while driving) then shut it down-do not let the rpms down, hit the kill switch.
#4 will tell you if you need to go up or down with the main jet. Too dark go leaner, too light go richer.
#3 will tell you if the needle needs to be adjusted (if it's adjustable on yours) Too dark, move clip up (or remove spacer) too light, move clip down (or add
spacer)
#2 will tell you if you need a bigger pilot jet. Too dark go leaner, too light go richer.
#1 will tell you if the pilot screw needs to be adjusted. Too dark, turn screw in. Too light, turn screw out. This is usually opposite on 2 strokes. If the air/fuel
screw is between throttle slide and motor, it usually regulates fuel flow(out richer). If the air/fuel screw is between throttle slide and air cleaner, it usually
regulates air(out leaner).
Main jet and pilot jet (Range #4 and 2) should be determined first. This will give you the max size it should be, then adjust your other 2 settings.
I couldn't quite remember the ranges properly before, that's why I only stated 3. I had to think about it for a minute. It will take you a bit of time to tune it this way, but it should run like a top once you've got it adjusted.
PS Another quick way to determine if it's too lean, when your running it start choking it. If it starts dieing right away, your either good in that range or already rich. If it starts running better as you choke it, then goes worse again as you get to full choke then you're lean but close. If it runs best at full choke
then you're way too lean.
Old Apr 5, 2006 | 11:49 PM
Sparky8370's Avatar
So you'll go a little richer, plus with normal gas I think you'd want to be a little richer also.
Old Apr 5, 2006 | 11:58 PM
Sparky8370's Avatar
what is the pilot jet??? where is it located?
Look At # 6 here
If your not familiar with reading diagrams, it will be a pain to locate it, but it should be on the motor side of the carb on the bottom. It may have a brass plug that would need to be drilled out ,slowly. Be careful drilling this out. Maybe an 1/8" below the plug is the screw. If you hit it, you could strip it out. If you do hit it and it's still usable, remember that when you hit it, it probably turned all the way in.
Old Apr 6, 2006 | 03:21 PM
  #15
ok i put a 165 main jet in its about plus 8 outside the spark plug is the same since i cleaned it no black no white no brown just the original steal on the tip if i was running to rich the whole spark plug would be too white right??? this is confusing stuff
Old Apr 6, 2006 | 04:16 PM
  #16
Sparky8370's Avatar
too rich=black plug
too lean=white plug
If it's really lean the metal electrode will turn white around the tip. It will kinda look like frost.
Old Apr 6, 2006 | 05:09 PM
  #17
its black around the bottom but not the tip the tip is clean i just don't want to blow it up white will blow it up right
Old Apr 6, 2006 | 09:18 PM
  #18
Sparky8370's Avatar
look at this chart
Big bousse
Sep 26, 2015 10:42 AM
Dirtbikemike1
Jul 21, 2015 04:13 AM
ghost civic
Jul 19, 2015 10:13 AM
Bob Maurice
1) Engine problems..
Jul 14, 2015 09:05 AM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
