400EX Pipes????
Old Nov 25, 2000 | 12:02 PM
Santa's Avatar
You will need to jet your carb when you install the pipe. The K&N filter will be a huge improvement over your stock filter. Just be sure to install the new filter before you jet your carb.
Install a 14t front sprocket and get new tires and your Yoshi quad will ROCK!!!!!
I'll email you a pic of my quad.
Old Nov 25, 2000 | 12:53 PM
Hellrazr400's Avatar
should have gotten the DMC. Don't say we didn't tell ya. 5 mph gain on top-end, the engine runs cooler, high flowing, and it's very throaty. Good luck with the Yoshy though.
Old Nov 28, 2000 | 04:27 AM
MadDogg's Avatar
I installed the slip-on WB R-series pipe this last week. IT IS VERY LOUD! Not the kind of setup you want for long trail rides. I noticed better takeoff at the MX track, but I'm not sure if the pipe or track conditions made the bigger difference. Fit and finish is A++... a major improvement over the Big Gun on my DR. Price, lack of info, and questions with fit and finish steered me away from DMC. But for all out mod engines, the DMC gets the most endorsements.
Old Nov 28, 2000 | 11:57 AM
pudjumper's Avatar
WB does not make a head pipe for the R4 slip on. I found this out after I called WB to order a head pipe. They do make a R4 complete system for $480. So if you plan any future mods (cams, port, bigger bore) go with a complete system. I found this out the hard way.
Old Nov 28, 2000 | 12:23 PM
  #15
Aaron10's Avatar
Go for the LRD. Get it chrome and it will run right at $360. Don't know any certain hp gains. But i know i can smoke other piped, jetted, and filtered ex's and mine is all stock except for pipe. I beat others from top to bottom and gained about 8 mph on top end.
Old Nov 28, 2000 | 06:42 PM
  #16
korn's Avatar
maddogg,
Did you jet or put a new filter on, or did you just put the pipe on? I had a DG on my old 250X and it was real loud, would the R4 be louder than that?
Old Dec 1, 2000 | 09:52 PM
  #17
korn's Avatar
Does anyone else know anything on the White Brothers R-series pipe??????
Old Dec 2, 2000 | 12:20 AM
  #18
Guest
Guest
Posts: n/a
my EX has a [url=www.strokerspeed.com]Stroker SX1[/a] and has the K&N airfilter/precharger and the Dyno/Jet Kit... i've found this perfect for just minor mods and if i decide to i can always return to the original setup... i am able to outrun warriors in the bottom of fourth
mrtidy
Feb 3, 2016 05:00 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
