250r 310 big bore jet problem
Old Jul 20, 2006 | 12:30 PM
slomoe's Avatar
Default 250r 310 big bore jet problem
Originally posted by: scoutt
so you are saying instead of 1 12oz oil per five gallons I should do like 16oz? the oil I mix it with says right on the bottle 50:1 is best, 1 12oz bottle to five gallons.
go buy a ratio rite it is a little cup with the ratio marked on the side very user freindly it will take your guess work away.
also whith the big bore 2 strokes it is very important to be aware of your jetting. you may need to rejet from inland to the coast.
Old Jul 20, 2006 | 02:54 PM
PorP's Avatar
i was running the esr 310 trx7 full port kit with LRD adjustable and no air box/K&N with a 38mm airstryker on an 86.
I was out a piston within 5 hours on that kit cause esr did not chamfer the exhaust port correctly, i took it to one of the few true 250R gods there really are who re-chamfered the ports, and touched up the porting, when he was done with it it was running a 190 mj (which was also the reccomended jet from esr), and i think i was running 42:1 (right around there 50:1 with a few extra squirts) with maxima oil, this was running 115 octane with the 114 octane dome in the head. i am at about 85' altitude.
Old Jul 20, 2006 | 04:48 PM
Atvstevo1337's Avatar
176 seems like way to small of a jet for a two stroke im running a 248 in my blaster with the 240 big bore kit.
Old Jul 20, 2006 | 05:27 PM
Hoppedrap's Avatar
well I have found the problem since nobody is willing to help on this forum.
ESR suggested my pilot jet be at least 50. the one I got from the kit is a 35. problem fixed.
That goes back to my intial post about checking your jetting, a small pilot like that will idle high, and if you stab it it will hesitate until it gets into the needle circut. I run a 55-58 pilot, CEL 4th from top, and a 210 main. 39PWK
  #15
Hoppedrap's Avatar
Were talking about Keihin not mikuni carbs
Old Jul 20, 2006 | 06:31 PM
  #16
scoutt's Avatar
Hoppedrap,
that is why I changed the main jet to a 175. inexperience was not realizing there was a pilot jet.
the jet kits you can get from esr only show a 185, how do you get a 190 or a 210? does the factory sell them?
that is exacly what was happening.
I talked to a guy over at the coast the same weekend and he told me he has gone through 3 kits and each one he melted the piston like I did. he said his jetting was perfect too. I wonder if his porting was messed up too? hope mine isn't.
I will get a 180-185 jets and play around with it. cheaper to foul a plug then to melt a piston [img]i/expressions/face-icon-small-smile.gif[/img] I will also get a ratio rite jug. I have seen those too.
I know this, but I did not realize the pilot jet. I thought my 175 was good enough. apparently I was wrong. 175 was perfect for inland, so I will more than likely jump to a 180 or 182
Thanks guys, this has helped a lot.
Old Jul 20, 2006 | 08:22 PM
  #17
Hoppedrap's Avatar
Heres a good link for two stroke carbs. http://www.duncanracing.com/techfaq/...-jetting.phtml
Your current jets should be fine for your setup, the only thing I would do is pickup a CEL needle and start on the third clip, 185 main,55-58 pilot. Then test each circut and adjust accordingly
Old Jul 20, 2006 | 09:28 PM
  #18
scoutt's Avatar
yeah, i was going to get a DGH needle and start on the 4th.
thanks, that is a great link. considered it bookmarked [img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 9, 2011 | 09:10 AM
  #19
jjdmx12's Avatar
50:1 is perfectly fine if its a full synthetic. 32 or 40:1 is for semi synthetic oil. full synthetic is 50:1 your good man.
Old Aug 11, 2011 | 01:12 AM
  #20
TexasRoadlawyer's Avatar
No Ruts, No Glory
JJ....you realize this thread is over 5 years old, right?
Dustinyoungs
Jul 24, 2015 07:18 AM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
CRamshaw777
Jul 18, 2015 05:46 PM
